Is a 100hp shot safe on a daily driver??
hey guys i dont know much about N20, other than it makes big power for cheap. Is it safe to run on your every day daily driver? what is better for the motor wet or dry?? Will it cause damage to the motor?
ok, so i did a search and it helped. My truck is less than 2 years old, do i need a new fuel pump, injectors?? I think the NGK TR6 spark plugs are a must have but i just want it to be safe, and i dont mind spending alot and doin it right.
Baltimore Whore
A hundred shot you might be ok with the stock pump, injectors.. It would be better if you spray a wet shot, but if you do shoot a dry shot spray it before the the MAF.. i wouldn't do plugs on that shot IMO..
John
John
i am thinkin for sure a wet shot and the TR6 plugs. I read something about a drive by wire throttle body is tricky and needs other things evolved to make nitrous work??? Will the HSW Sudden Impact kit have everything i need? and where is the best place to put a bottle in a extended cab? i have a sub box under my backseat. do switches and buttons come with a kit or is that an accessory??
i dont have a tool box. i just dont know where i could put a bottle. what are yal's opinions on some of the best kits? I like the HSW sudden impact kit, what do you guys think? Is that a good kit or not? what is?
