100shot 1/4 mile
Old 01-26-2009 | 04:17 PM
  #21
parish8's Avatar
single digit dreamer
yep, i sprayed on a stock converter right off the line. if your going to try it make sure you have $500 for an engine laying around and a fire extinguisher.
Old 01-27-2009 | 01:44 AM
  #22
slidesquad's Avatar
is that a joke lol i am confused.. how did every thing hold up if you did spray off the line how many times did you do it?
Old 01-27-2009 | 05:38 AM
  #23
Turbocoop's Avatar
haha, that sucks. i hope you got it on video
Old 01-27-2009 | 06:01 AM
  #24
LowBlack99's Avatar
I ran 13.9 with a CAI, hypercrap on the trans, lowered 4/6 on 20's, stock engine tune,stock converter,stock 3.42w/g80,80shot dry, full weight, 5.3. Trapped 98xxx. You should be able to get in that range. Altitude and weather make difference also. With lt's and a still stock tune I went 13.7. No track times since the tune, to be honest Im scared to run it with the stock 4l60 now. Don't wanna walk home!
Old 01-27-2009 | 06:48 AM
  #25
parish8's Avatar
i am not saying i blew up the motor. i did it hundreds of times. one time wacked it from an idle and had a backfire. the truck belched a little fire and blew up the intake tube.
i am trying to let you know it is risky to spray from that low but it works.
if you want till 3000rpm to spray that 4.8 your et is going to suck. to do it right a decent converter is all you really need.
Old 01-27-2009 | 01:55 PM
  #26
slidesquad's Avatar
i just tested it out at 1900 rpm lol it makes some f***ing tq down there hahahahaha i am going to try this at the track next week if the et streets hook up ill let you guys know how i did.. ill have a camera too in case i blow haha
Old 01-27-2009 | 01:57 PM
  #27
nighthawk08's Avatar
while we're on the subject...what causes the backfires? is it just a lack of airflow coming through the engine at low rpms?
Old 01-27-2009 | 03:56 PM
  #28
parish8's Avatar
yeah i think that is what it is. too much fuel spraying and not enough air so it pools. if you give it a little brake stall everything should be ok but if you forget and just wack it from an idle things can get ugly.
Old 01-27-2009 | 03:59 PM
  #29
yeah i witnessed it a few weeks ago on a 4.8 truck at the track. it wasn't pretty.
Old 01-28-2009 | 12:25 AM
  #30
slidesquad's Avatar
another issue with nitrous is a 100 shot at 1900 rpm is 276 lbs of tq lol
Quick Reply: 100shot 1/4 mile
