150 shot in 2000 5.3l iron block?
just wondering how safe it would be to spray a 150 shot on my 2000 5.3l iron block with an LS6 cam? i expect my 4l60e to crap out on me eventually but how much should this speed it up? i expect to get a 4l80e afterwards.
ALSO, how safe is it to spray with a turbo, not until much further in the future but just to know. all assuming i will get PCM retuned.
i ran about 3 bottles on a 150 shot..motor screamed just fine..it was just the trans that took a **** on me TWICE..
by the way what rpm do you shift with your ls6 cam?? kinda thinkin about gettin one
FormerVendor
You should be ok. Do you know if MTI advanced your timing any with the tune? If they did you might want to pull what they advanced back out, or run a higher octane fuel when you spray.
Matt
Matt
i shift at 6200 rpm, yes they advanced the timing, i run 93 octane fuel all the time, sometimes i buy an octane boost to 104 or something but yea, i figured i would have to take some timing away. how long should my 4l60e last with a 150? i would get a tranny cooler, i have 80k on the truck and it towed for probably about 4k of those miles. how long until i need a 4l80
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
yea i knew about the spraying through shift damage stuff and window switch, thanks, how much should a 150 wet shot kit and instal run me? estimate
ZO6Ted
08-12-2015 07:50 PM
Gadgetized
07-07-2015 04:40 PM
