Almost done with the setup on Dirty II
Man that's exactly how I wanted to do my setup. Looks great! Kinda disappointing that the center console is completely used up with the bottle though.
And I was just going to ask where the solenoids were, lol. I scrolled up and looked again. Ridiculously hidden.
You're right the cup holders are def not going to fit. When the bottle is out of the truck, I'll be using the stock cupholders. When I plan on doing a little racing, I'm having a company fab me up an abs plasic piece that just covers the hole where the cupholders go. Then I'm going to mount a little power adaptor on the cover that I some times use for things in the truck(laptop,etc.) Should be a good concealed setup for what I'm looking to do.
Thanks Trey! You're def right there. It might end up being an issue. I'm trying my hardest to figure out a way to get the bottle turned around, but it just isn't quite enough room the other way to make it work. I did a little research on some past threads and the two guys I found that did this also said they weren't having any problems with them even when the bottles were getting low. That is pretty encourageing, but I'll def post up my findings as soon as I go through the first bottle.
then you get your console and cup holder back.
I always wanted to put the nitrous bottle under the truck bolted to the frame. might as well take advantage of having a truck with all of that room underneath. ultimately i'm lazy and just threw it under the back seat. refills sounded like a PITA.
the bottle fits perfect under the back seat (assuming your not running a sub box under the rear seat. you can put it directly behind the drivers seat under the back seat facing forward. then cut the bottom out of a gym bag or duffel bag and slip it over the top of the nitrous bottle. maybe put a bat and baseball glove on top of the bag for extra convincing.
Hm........Think I might swap it over to there this week. I have alot more time to play with it now that its going to be down for alittle while. Thanks for the heads up guys!
