Big nitrous back fire=bent valve, Need HELP
Old 05-22-2011 | 03:39 PM
LS1TRUCKGUY's Avatar
I run 31* timing, but im only using a 52n 29f for 11.8afr
Old 05-22-2011 | 04:22 PM
70ls1chevelle's Avatar
Originally Posted by BadAssChevy327
out of curisoty in which way is the nitrous deleivered? plate or nozzle?
Nitrous Outlet plate
Old 05-23-2011 | 02:33 PM
krambo's Avatar
Originally Posted by silver-mod-o
Could have lean spiked too. One guy here runs Tr6 plugs, 26 deg timing on a 175 hit out of the hole and has no issues. Looking to bump to 200 and put timing at 21 deg. AFR is about 12.4 on the big end.
Timing is relative to the engine and efficiency of the chamber...there is no set mark that is right or wrong. Reading the plugs is the only way to know where you stand. silver-mod-o, I like the AFR you described however the TR-6 plugs are not the ideal plug (I am sure you and the owner of that truck are aware). I have read where some of the N2O guru's are running 5* of advance and AFR's in the 13's because that is what the plug is telling them. Check out yellowbullit dot com for some great nitrous talk.
What size nitrous feed line are you running? A -4AN could be an issue when spraying that size shot.
Old 05-26-2011 | 05:04 AM
kelsey_canard's Avatar
This would cause a rich condition wouldn't it. I'm more opted to say it's too much timing and maybe poor delivery across the cylinders.
Old 05-26-2011 | 05:09 AM
unless trying to cram that much nitrous through that size line made the spray pattern coming out of the plate funky, and not evenly distributing the n20
Old 05-27-2011 | 12:43 PM
krambo's Avatar
Indeed it will as you state. The feed line size was just a quick side conversation. I feel the timing / plug choice is the root cause as well.
zblee
63
06-10-2023 02:25 PM
The_W
10-28-2015 10:00 PM
InsaneDomestics
07-27-2015 03:42 PM
low2001gmc
07-23-2015 06:10 PM
Mossyoakglock
07-17-2015 09:30 AM
