Bottle heater question
11 Second Truck Club
I'd be willing to bet that 80% of the people on this board couldn't pick a relay out of a line up!
Lets take a vote how many people understand a relay and what it does for you?
Moderately Differentiated
Get a pressure switch and put on the BOTTLE. Why bottle? Because you may close the bottle and leave the heater on and have an empty line while you are playing the radio talking with your pals.
Then run the ground wire for the relay coil through it. So, a wire from ground to the pressure switch then a wire from the pressure to the #85 or #86 terminal on the relay. Then a wire from a key on hot 12v source to #85 or #86. If ground is #85 then positive is #86. Vice a versa. Those wires can be relatively small. 16AWG is fine.
Then from a constant 12volt source run at least a 12AWG wire (10AWG will erase all worries) to the #30 terminal on the relay. The another 12AWG wire from #87 terminal on the relay to the positive wire on the heater. Of course, run the same size wire for the ground on the heater as well. It can be directly to ground, but near battery ground is better.
I'd say never use a relay smaller than 30 Amp rated. The more money you put into one the longer it will last. (Contact surface of internal contacts take a beating from arching.)
Brake fluid and relays dont play well together....
Finally got some new ones and replaced these with...
When i was younger i was helping my brother put a sound system in his S-10 and he never knew how to wire a relay up..
It took me quite awhile but i figured it out but they are pretty cool how they work..
creekrat
09-10-2015 12:59 AM
iregret
09-07-2015 01:20 PM
