custom sneaky pete
yeah, thats the idea.
Reverse routing... 1 nozzle (fuel/n2o), mounted at the mouth of the TB, screwed to the bottom of the intake tube, with a slight angle upward. Snake the lines through the intake tubing, , pop them out right before the MAF, wrapped in either corrugated plastic or vaccuum line, and quickly into something that would resemble a relay box and contain the solenoids, windowswitch, etc...
As for the bottle, maybe mounted to a framerail, or under the gutted glove box??
I think that it'd work.
A nitrous sponsor here recently posted an ls6 intake with the nozzle under the intake manifold. Look for that, would be badass on a truck manifold. Then just spray the lines flat black and run them down the side of transmission, then back over to rail, install a small bottle here and your golden.
-Lurius
-Lurius
Originally Posted by cablebandit
LOL..Quicksilverado and the ole rag in the i/c trick. I think he did it to see if less flow would give the air more time to be cooled
HAHA I HAD A BODYSHOP RECENTLY WHO WAS FIXING A BRAND NEW C6Z06 AND HE COULDNT FIGURE OUT WHY IT WOULDNT START.
TURNS OUT HE LEFT A SHOP RAG IN THE TB AND PUT THE INTAKE BACK ON...
THE TECHS HAD A FIELD DAY WITH HIM....
-Lurius
-Lurius
Nitro daves has the moneymaker intake that is completely concealed. he posted it here a couple of days ago and it works with a truck intake. I think its a wet sytem with shots from 35-300
https://ls1tech.com/forums/showthread.php?t=384727
Linky
Linky
Guest
Posts: n/a
-Lurius
-Lurius
this is not the intake you are talking about but it is a hidden system capable of spraying up to a 300 shot.
http://www.nitrousoutlet.com/installs/install.asp?id=9
we can do it on a truck manifold also
Originally Posted by '89ChevyMadneSS
what about the guys with the nozzles plumbed into their cold airs and such??
