Does any manufacturer make........
........a Holley 4150 nitrous plate that is high fuel pressure EFI compatible? Because the Mopar M1 4bbl EFI manifold I'm using runs a Holley pattern and I'm planning on running a plate style nitrous setup under my throttle body. I was planning on tapping off the fuel line for the nitrous fuel supply, but seems all plates are designed for low pressure carb stuff. My other more expensive option is to run a dedicated low pressure fuel system just for the nitrous. That was actually the original plan but it'd be cheaper if I can find the right plate. Last option, which now that I think about it should be the first, LOL...is to use the FAST system and just add the fuel through the injectors and have just a nitrous spray bar in the plate. I'm trying to stay away from the nozzle setup as I'm running a 14X3 K&N air filter and dont wanna go to a cold air intake setup. I figure a plate style spray bar would give much more even distribution.
I inquired about this a couple months ago as well, here's exactly what the guy from Wilson sent me:
There is no problem with using our plates on a high pressure system. The
only thing that will change is the fuel jet. If you were running 49 psi
fuel pressure your jetting for our plate system should be as follows.
N2O Fuel HP
46 28 75
50 31 100
56 34 125
65 40 150
73 45 175
82 50 225
92 57 275
102 63 325
110 68 350
I'm rather curious about the plates tho, seems that even the wet setups use a single bar to feed both the N2O and fuel. Maybe i'm missing something here but it just does not seem right.
As for using the FAST to trigger it, keeping the wet system that would be cool but honestly I wouldn't do it setup Dry. Means you are gonna be changing programs everytime you want to run the juice etc. Won't run mine that way at least. Gonna have it setup to fire both solenoids at a given rpm and then let it trim the a/f from there. Just set the fuel correction limit very low on the lean side to be safe.
N2O Fuel HP
46 28 75
50 31 100
56 34 125
65 40 150
73 45 175
82 50 225
92 57 275
102 63 325
110 68 350
Former Vendor
Ricky
Originally Posted by Five9Dak
Does anyone have a M1 2bbl plate system? I dont really wanna a shark nozzle and I think the 4bbl M1 would be overkill for my mild NA set up.
And your correct, you would absolutely hate the 4bbl M1, takes a very healthy 360 or 408 to really use it.
BigE
02-21-2018 11:44 AM
FlowmasterMufflers
11-24-2015 01:00 PM
FlowmasterMufflers
09-11-2015 03:32 PM
FlowmasterMufflers
08-31-2015 05:11 PM
