dry to wet conversion...
i am going to do this with my dry kit soon, and i am expecting to drop a few tenths at the track with the same/similar size jets.
i noticed on the dyno that my dry juice is flywheel rated, as i only picked up 75ish of the 100 dry i was spraying...
i am gonna convert to a regular intake jetted style wet kit, with a 100-125 shot...
am i crazy to think that i will gain a few tenths? it should be another 75 or so rwhp, with the 125 wet kit in there, shouldnt it?
i wasnt asking if it could be done, or how to do it, i was just asking if i was correct in assuming the conversion would result in a lower timeslip.... with the added horsepower rating the wet kits have over dry.
i do appreciate the compliments though
well, the dry is rated at the flywheel , whereas a wet is rwhp rated.... so i assumed if i went from 100 dry (about 75 rwhp) to a 125 wet, i should pick up a good bit at the track... shouldnt i ?
that was my initial question.
Why don't you just up the dry shot? The main benefit of using a wet setup is if the injectors will not support the target HP, other than that, HP = HP for the most part, regardless of if it's flywheel or rearwheel rated.
SlvrSierra4.8
10-01-2015 10:39 PM
