February Tax Time Specials!!!
LS1TECH & TRUCK Sponsor
Its that wonderful time of the year!!!! Tax Time With nice weather and race season right around the corner what a better time to start getting the hot rod ready for race season. To help you stretch that Tax refund alittle further than expected we have put together some specials for the month of February.
NOTE:Nitrous Outlet uses only the best products in there nitrous systems.
All the Nitrous systems in the following group specials come with solenoids designed to flow 300hp, Nitrous solenoid has purge port design, The bottle valvewill flow 800 hp and has two accessory ports, quick release stainless steel bottle brackets, 16 ft main feed line,2 ft hoses from solenoids to nozzle, and all the needed hardware to complete your install.
(Dry systems have a 20 ft Main feed line)
Group 1
Nothing beats a Nitrous Outlet Plate system....
Your choice of a 78mm or 90/LS2 plate system.
860 Heated bottle bracket
Purge kit
Fuel pressure safety switch
Nitrous pressure gauge
NHRA Blow off valve
Blow down tube
Dual digital windowswitch with built in tps and any gear lock out feature
NGK TR6 Spark Plugs
COST-1075.00
Group 2
This is a new set up that is sure to be a favorite. I will have pictures to share soon.
Dual nozzle special.
This system comes pre mounted onto our maff style solenoid bracket.
The system is already pre fit for the cleanest look possible. No fitment issues!!! Lines are the perfect length for a custom looking fit.
System includes
Dual nozzle system
Maff style solenoid bracket
Purge kit
COST- 600.00
Group 3
Dual nozzle dry system
Purge kit
NHRA Blow off valve
Blow down tube
NGK TR6 Spark Plugs
COST-775.00
Group 4
GM single nozzle Wet system
NHRA filtting
Blow down tube
Nitrous Outlet purge kit
Digital dual window switch (Has built in TPS and any gear lock out feature)
NGK TR6 Spark Plugs
COST-875.00
February Discounted Items.
1. Nitrous Express Power Booster.
COST-10.00
2. NOS Blue Purge light.
COST-29.99
3. Zex Bottle Pressure gauge & Manafold
COST-37.00
4. Nitrous Outlet Big Show Purge.
This purge kit comes with a 116 orfice nitrous solenoid and 3ft of 1/4 alluminum purge line
COST-99.00
You can call in your order at 1-866-648-7637
Thank you for your support
Dave
Group 1
Purge kit
NHRA Blow off valve
Blow down tube
NGK TR6 Spark Plugs
COST-1075.00
Group 2
System includes
Dual nozzle system
Purge kit
COST- 600.00
Group 3
Purge kit
NHRA Blow off valve
Blow down tube
NGK TR6 Spark Plugs
COST-775.00
Group 4
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST-875.00
COST-10.00
COST-29.99
COST-37.00
COST-99.00
Dave
05GMC4.8
08-07-2015 09:55 PM
ullose272
11
07-17-2015 07:22 AM
