Finished Nano/Nitrous Rack
Old 03-05-2009 | 11:09 PM
leftcoast32's Avatar
FormerVendor
Default Finished Nano/Nitrous Rack
We got the Nano/Nitrous Rack back from powdercoat and finished the installation.
We had the bottoms of the bottles done in Line-X to prevent chipping.
We sanded and then covered the aluminum panels in clear acrylic enamel.
The lines (-6 Nitrous and -8 Blow Off) have bulkhead fittings in the floor of the compartment. This is so we can pull the lines and cap the bulkhead fittings when not in use. Once the lines are pulled the compartment cover can be reinstalled.
Old 03-05-2009 | 11:12 PM
nonnieselman's Avatar
Ive been waiting to see an install from somebody..
Looks great!
like the bed lining also.
Old 03-06-2009 | 12:21 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
it's just a bottle
Looks killer Joe, sweet install!
Old 03-06-2009 | 09:14 PM
FormerVendor
Here are some pictures of the Nitrous Solenoid/Relay Brackets. Everything mounts up behind the headlights for easy service. The Switch Panel will be mounted inside the center consol out of site. We need to finish up the lines, wiring and NOS Launcher with 3.5 LCD Touch Screen then off for some testing. The Purg blows out the brake cooling duct on the passenger side of the front bumper.
Before Powdercoat:
After Powdercoat:
Nitrous/Fuel Solenoid Bracket
Purg/Relay Bracket
Old 03-10-2009 | 01:24 AM
jaegmc99's Avatar
wow this work is amazing. As simple as it is, I never thought of making seperate brackets for my nitrous accessories. Great idea! got any more pictures of the interior, seats and harness setup?
Old 03-10-2009 | 01:51 AM
One_Slow4.8's Avatar
don't you be getting any more ideas now..... lol
Old 03-10-2009 | 02:15 AM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
Joe,
Its looking really good.
Dave
Old 03-10-2009 | 10:15 AM
FormerVendor
Thanks for all the great comments!!
Thanks, here is a link to almost all of the build to date.
https://www.performancetrucks.net/fo...d.php?t=400482
Old 03-10-2009 | 09:38 PM
FormerVendor
I still have alot of wiring to do but here are some progress pictures.
Nitrous Hi Flow Filter and 1/8 NPT Port for Nitrous Pressure Sending Unit
Relay Bracket with Purg Finished (Sprays out the Brake Duct on Passenger Side)
Nitrous and Fuel Solenoids (Lines Finished)
Nitrous Spray Bar Inlet with Lines Attached
Stand Alone Fuel System with Pressure Regulator and Fuel Pressure Gauge (1/8 NPT Port for Fuel Pressure Sending Unit)
Old 03-11-2009 | 12:27 AM
1989k1500's Avatar
Looks awesome!!!!
