Fittings help please.
I have a -4an to 1/8 npt that i want to run a .100 pill in. This will act as a restrictor for my oil feed to the turbo. I need to put the jet in line, the 1/8 will go directly into the turbo so it will have to be on the -4an side but i can't find the correct fitting. Can someone help me? I guess i don't know what to ask for?
FormerVendor
That's not gonna work. The jet acts as the 37* flare required to seat with the hose. What you can use are one of these...its the fitting we use on our plate systems to hold the jet. One side is 1/8NPT and the other is drilled to except jets and a -3 hose. We can also put a 3AN b-nut onto a -4 hose if that's the size you need for flow.
They're the fittings on the ends. We generally don't sell them separate but give us a call and we'll help you out.
Nick
Nick
FlowmasterMufflers
11-24-2015 01:00 PM
FlowmasterMufflers
09-11-2015 03:32 PM
LSX-81-SIERRA
09-05-2015 02:51 PM
