fueling help.... need your opinion
Old 01-13-2011, 01:12 PM
11 Second Truck Club
fastrt's Avatar
I did the timing trick, but you will need efi live or hp tuners to do it. works like a champ.
Old 01-13-2011, 01:26 PM
idahoblkss's Avatar
how did you set your up on a WOT switch ? ideally it would be cool if it only turned on when the nitrous is armed and when you are wot "or when you start spraying"
Old 01-13-2011, 01:30 PM
fastrt's Avatar
Well, I run a trick controller for WOT, but as far as the timing trick, I have the relay turn on when I arm the system.
Old 01-13-2011, 01:38 PM
idahoblkss's Avatar
doesnt that make you run like crap till it starts spraying?
Old 01-13-2011, 04:01 PM
fastrt's Avatar
I dont arm it till I am about to stage. I have never sprayed on the street, but if I did, I would't arm it till I am about to use it. I never felt a diff, but I only pull 3*, and by the time I get me a stand alone, I wont pull any.
Old 01-13-2011, 04:52 PM
idahoblkss's Avatar
rick at TRICK has these new composite tanks that he has and will probably be building me a stand alone... why will you not pull with a stand alone ? i thought you still have to pull timing no matter what?
Old 01-13-2011, 05:55 PM
Laid Back
Beatdown Z's Avatar
He'll probably fill his stand alone tank with some 110 or higher octane fuel...
Old 01-13-2011, 06:00 PM
fastrt's Avatar
BINGO
Old 01-13-2011, 06:11 PM
idahoblkss's Avatar
Does that go for boosted aps. too.. im running on e85 too
Old 01-13-2011, 08:43 PM
fastrt's Avatar
ummm, I am not sure on that one. may ask in the forced induction section.
Quick Reply: fueling help.... need your opinion
