I did the timing trick, but you will need efi live or hp tuners to do it. works like a champ.
how did you set your up on a WOT switch ? ideally it would be cool if it only turned on when the nitrous is armed and when you are wot "or when you start spraying"
doesnt that make you run like crap till it starts spraying?
I dont arm it till I am about to stage. I have never sprayed on the street, but if I did, I would't arm it till I am about to use it. I never felt a diff, but I only pull 3*, and by the time I get me a stand alone, I wont pull any.
rick at TRICK has these new composite tanks that he has and will probably be building me a stand alone... why will you not pull with a stand alone ? i thought you still have to pull timing no matter what?
