fueling help.... need your opinion
Old 01-13-2011, 09:16 PM
  #21
milkey57's Avatar
Quick question since were both goin the same way, with the stand alone are you gonna run colder non projected tip plugs too? There has been so much debate on ls1 im just tryin to figure out everything. Thanks!
Old 01-14-2011, 11:55 PM
  #22
idahoblkss's Avatar
i em running tr6's right now and was told that they would be fine up to a 100 shot, if you plan on going more then that you might want to go to a 7 series plug but not sure on that just what i have read.
Old 01-15-2011, 11:47 AM
  #23
Laid Back
Beatdown Z's Avatar
Do a little searching on reading plugs and you'll find that you can determine if you need hotter/colder plugs by reading the ones you have now. It would probably be best to start with a colder plug and adjust from there.
In my 10.8:1 compression 6.0, I plan to run non-projected NGK BR7EF's with a 150 shot...
Old 01-15-2011, 09:38 PM
  #24
milkey57's Avatar
I have the BR7EF's ready to go in when the stand alone gets here you're right better safe then sorry! We'll see how they work out i'm hoping that i can become a pro at the plug reading too
Old 01-21-2011, 07:46 PM
  #25
idahoblkss's Avatar
Ordered my trick performance stand alone fuel kit today.... so far rick has been very helpfull and said I should have the unit in two weeks... I will let you guys know how it goes and will be posting pics asap...
Old 01-22-2011, 01:42 PM
  #26
milkey57's Avatar
looks like were doin the same thing, i can't wait for it to show up! Did you do the plastic or aluminum one?
Old 01-22-2011, 01:49 PM
  #27
2004SSS's Avatar
nitrous now? why not just throw a d1 on it and have the power all the time?
Old 01-22-2011, 05:49 PM
  #28
idahoblkss's Avatar
I just did the composite im going to probably paint it black... going with the all black look.
Im trying to get my low end going here. I talked to procharger at sema about the d1 upgrade and said it would be a great upgrade but it wouldn't help my low end at all and they said the d1 acually spools later then the P1, and that's why im going n20 right now. I still want to do the d1 but going to get this going first.
Old 02-23-2011, 01:49 AM
  #29
idahoblkss's Avatar
tank came and looks awsome... rick from trick performance is a great guy to work with and has unlimited info. i would strongly recomend him to anybody ... more pics soon...
Old 02-23-2011, 03:07 AM
  #30
2004SSS's Avatar
intstall pics by tomorrow
Quick Reply: fueling help.... need your opinion
