going from wet to dry?
[QUOTE=Black'Rado;4499272] My question is, can i just get a T fitting to go on the out of my n2o noid and run 2 lines to my plate and just use 2 nitrous jets for a dry system? and of course eliminate the fuel noid. QUOTE]
As far as I know I dont think there is a difference between the HSW Dry and Wet plates, but I could be wrong.
Yep, I capped the fuel side with a vacuum cap. Command 11.5 pe instead of 12.6 and spray a 75 dry through a 78mm harris plate. Hits hard! A/F goes to low 12's on my lm1 logged serial with efilive. I have a 98 pcm , so I have to switch tunes back and forth. I like the dry because it goes rich first then leans out on juice and a wet kit spikes lean when first hit then stabilizes. Also , wet kit require a bizillion jets to fine tune. Why? when I have complete control over fueling with EFIlive. warning, people will give you crap about doing it this way!! new ideas scare people.
