going from wet to dry?
#21
only sprayed it 2 times with the 75 but it was going lean so i just fixed my fuel pressure issue.
tommorow i might put in the 100 or 150 on the dyno. im pretty close to runing out of injector so ill see what it can take safely
#24
#27
its easier just to swap a jet than have to change the tune.
ive decided to just skip over the 75 and throw the 100 in since its tuned conservative on just 24* timing. Before i was shootin the 75 on 26* with no problem.
Im sure the 100 will be rich as well.
#28
What could be easier than smashing a few buttons. just knock .5 off your commanded pe and see how it does. It will pick it up some and on the same size shot. Do more with less. You do have efilive right?
#30
I deal in A/F ratio, but yeah i change my pe to 11.7 to 1 instead of 12.7 to 1 and spray dry. You could change you commanded whatever is equal to a half a point change. IE 12.5 to 12.0 to 1 . I would not go too lean without logging a wideband, but the gains from running a low 12.XX to 1 over your 11.XX to 1 are gonna leave you smiling.
