HSW 78mm Plate Kit
HSW 78mm Plate Kit
Guys, I recently bought one of these kits from HSW. I went to install the bastard and the bracket for the extending the throttle cable
mounts doesn't appear to work on the truck. It almost Seems as if I hae the fbody bracket. Has anyone else ran into this problem? Does anyone have a photo of the bracket installed on your truck? Also, where are you guys mounting your microswitch? Post up some pics with an explanation of how you mounted it if you don't mind! Thanks!
my kit had the same throttle cable bracket. im pretty sure its the f-body bracket. i had an old tb spacer bracket laying around, so i used it instead. it doesnt matter which way you mount the noids. i cant help you on the microswitch, since im using the microedge with the tps sensor.
I might have that bracket from my kit. I'll look for it tomorrow, if I find it, I'll PM you and sent it your way. As for the solenoids, I don't think it matters how you mount them, just get the flow correct.
