jets for 50 shot zex
cant seem to find any actual charts for a zex 50 shot, but from what ive read, zex is the same as nx. Is that correct? if so, the master nitrous list says i can use a 35n and 18f jets to get the 50 shot (thats according to the nx specs). Just wanted to ensure this before i go sprayin the truck. Perhaps someone else has set up there zex kit for a 50 shot? Just wanted to start small and see how the turbo reacts. most likely wont ever go past a 75 shot. thanks guys.
well guys, i dug a little deeper and did a bit of research. found the chart below:
http://www.zex.com/catalog/ZEX101-05/PG22.pdf
the directions that came with my zex kit call for fuel jets that are 2 sizes smaller than the chart above probably due to the higher lsx fuel pressure. in that case, subtract 2 from the fuel jet and you have the right combo. so if the mods want to add the following list to the master list sticky, it will help any other zex users
ZEX LSX wet
55hp-32N, 17F
65hp-36N, 19F
75hp-40N, 24F
100hp-46N, 28F
125hp-54N, 32F
ZEX LSX wet
55hp-32N, 17F
65hp-36N, 19F
75hp-40N, 24F
100hp-46N, 28F
125hp-54N, 32F
i was gonna say that you can just email the sales dept and zex and they will give you what you need depending on your setup.... i had a similar question and they answered it for me in just a few minutes.... just my info... glad you got what you need
