Nano Street/Strip Systems!!
Old 09-11-2008 | 05:08 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
Default Nano Street/Strip Systems!!
Nitrous Outlet would like to Introduce a more cost affective street/strip version of the Nano System for the average user not looking to spray more than 175 HP.
Nano Has worked hard at listening to your needs. After much thought process and time they have developed a Nano system deigned for the street/strip application looking to save a few dollars.
You can purchase these units at a discounted price while supplies last.
Nano 3000 Universal System with Out Bottle Valve
Designed to work in configuration with other valves that are Flow acceptable.
Supports horse power levels up to 175.
ONLY 399.00
Nano 3000 Sport System
Comes complete with your choice of 10 or 15lb bottle valve.
ONLY 469.00
You can call in your order at 1-866-648-7637.
We will have them on our website shortly.
If you have any question to if your current valve will work with the universal system please ask.
Thank you for your support.
Dave
Old 09-11-2008 | 07:49 PM
southern_chevy's Avatar
I have seen a few of these and still want to know what they do?
Old 09-11-2008 | 09:26 PM
99Silverado5.3's Avatar
"Nitrogen push"..you will have ideal nitrous pressure when it's activated down to the last pound..no more wasting the last several pounds in a bottle or being down on power with low pressure. Typical gains are a few tenths/mph in the 1/4 due to the constant pressure ALL the way down the track..no steady bleeding of pressure like normal nitrous kits when activated.
Old 09-11-2008 | 10:38 PM
Ic now it all make since now.
Old 09-12-2008 | 09:40 AM
Here is a good technical read..
http://www.nitroustech.com/forums/showthread.php?t=155
Old 09-13-2008 | 11:28 AM
built408's Avatar
Good prices, but I need something for about a 250-300 shot, and I have no room to put the nitrogen bottle
Old 09-17-2008 | 05:56 PM
Turbocoop's Avatar
damn thats a good idea. I hate how I cant use the last 1 or 2 lbs in the bottle cause theres not enough pressure. Too bad I cant afford it and I dont use my nitrous enough to need it. Thats great for real drag racers though. Good deal
Old 10-06-2008 | 06:31 PM
You need the competetions system. Its good up to 500HP.
Dave
Old 10-06-2008 | 06:42 PM
vff_jeff's Avatar
Will it work on a NX bottle?
Old 10-06-2008 | 07:09 PM
Yes. And if you have the new style 45 valve you will not need the sport version. You can use the universal system.
Quick Reply: Nano Street/Strip Systems!!
