Need fuel shut off valve (Nitrous Outlet)
Old 09-22-2011 | 09:48 PM
Holty's Avatar
Notorious BIG
Default Need fuel shut off valve (Nitrous Outlet)
Hey can anyone tell me what i need (what size) to install a fuel shut off valve right before my fuel pressure safety switch? (Red fittings is fuel)
Old 09-23-2011 | 10:39 AM
SRTKLLR's Avatar
What is a fuel shutoff valve and what does it do?
The fuel pressure safety switch cuts both the N20 and fuel solenoids when the fuel pressure drops.
Old 09-23-2011 | 11:00 AM
Holty's Avatar
Notorious BIG
I"m picturing something like this just so i can remove the fuel line going from my fuel rail to my fuel noid without dumping fuel all over the place. i just dont kknow what size i need.
Old 09-23-2011 | 11:05 AM
Holty's Avatar
Notorious BIG
or maybe something like this?
Old 09-23-2011 | 12:27 PM
SRTKLLR's Avatar
Once the system is installed you should not have to be removing it.
If you have to remove it for any reason like I did to install a fuel pressure gauge then what I do is turn on the truck and open the hood. Then I pull the fuel pump relay out and wait until it turns off. After that it has very little fuel left in the line so I just put a rag under the line and remove.
With the valve you will also get a little fuel left in the line even when closed.
Old 09-23-2011 | 12:41 PM
Holty's Avatar
Notorious BIG
I realize this, the system has been installed for 3 years.
I realize this, the system has been installed for 3 years. I plan on removing it temporarily to create a new bracket and i dont want to be "down" the entire time as i dont know when it will be done. I'd rather have a valve instead of a cap on the fuel rail.
Old 09-23-2011 | 02:35 PM
TXsilverado's Avatar
sounds like a waste of money to be honest. pull the line from the fuel rail and put the schrader valve back in. when you're done with the bracket just put it back together in reverse order.
Old 09-28-2011 | 11:30 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
Like suggested above just run down to your local parts store and get a sharder valve for a few dollars.
Dave
The_W
10-28-2015 10:00 PM
slowlsx
08-13-2015 09:28 PM
Mossyoakglock
07-17-2015 09:30 AM
4B11T
07-13-2015 04:48 PM
jrplz
07-09-2015 01:07 AM
