Nitrous on 5.3
Old 11-20-2005, 05:48 PM
9 Second Truck Club
tarinitup's Avatar
Default Nitrous on 5.3
After spending 3 months trying to make power on a powerdyne I am calling it quits. I started with 220 HP on my 5.3 and with the powerdyne, injectors, and tune I only got 305. I am thinking of going to nitrous but I want some opinions first. How much power can I make with nitrous safely. I already have 44lb injectors and can retune anytime. Also, what kit do you guys recommend. Can I run 13s on nitrous with a 5.3?
Old 11-20-2005, 06:22 PM
Truck addict
goshawk23's Avatar
i won't recommend a kit since i built my own. but you should be able to get into the 13's easy with nitrous. traction provided, and weather you are going to spray out of the hole. i would start with a 100 shot then if you feel the need go up to a 125. 150 is about where i would stop spraying on stock fuel pump and rods and such.
Old 11-20-2005, 08:11 PM
9 Second Truck Club
tarinitup's Avatar
Thanks for the info. Also, what is the benefit of spraying off the line. I don't know exactly how nitrous works but don't you want all the power at the end?
Old 11-20-2005, 09:29 PM
Destroyer of Transmissions
1SlowHoe's Avatar
http://www.nitrousdirect.com/
These guys are sponsors of this site and will answer any queations you have. Ask for Scott and tell them I sent you.
Need Help Ordering? 954-650-7951
If I could stop blowing up my engines with my blower I'd install the kit sitting in my gagrage. LOL
Old 11-20-2005, 09:50 PM
blownerator
BlownChevy's Avatar
IF you are going nitrous, go with the nitrous direct system....nice kit IMO. (complement from a blower guy)
Old 11-20-2005, 10:24 PM
9 Second Truck Club
tarinitup's Avatar
thanks for the info
Old 11-21-2005, 07:04 AM
JimS's Avatar
BlownChevy..... what do you think about nitrous on a 5.3 w/the Radix?
Old 11-21-2005, 08:24 AM
NitrousDirect's Avatar
Thanks guys, and yes I'd be happy to help you make safe power! Give us a call
Old 11-21-2005, 09:34 AM
blownerator
BlownChevy's Avatar
I think I cant comment on that But I am sure others will.
Old 11-21-2005, 05:12 PM
1SlowHoe's Avatar
Nitrous is an oxidizer. It will do unwanted things to your aluminum Radix housing and the rotors inside. You're not gonna want to spray much because the super cooling effect of the N2O on the boosted air is gonna be a kick in the *** just as much as the nitrous itself. I'm gonna try it one day. I have the kit in my garage. If I ever get it installed, that's another issue...time management required. I would start at a 35 shot and then move up in small increments from there. Say to 50 then 60 then 75. Until something breaks, and it will. Do a wet shot, dry is asking for trouble. Make sure your AFR is very good before any of this.
Quick Reply: Nitrous on 5.3
