nitrous and meth
Has anyone tryed meth and water injection on top of there nitrous shot . I was thinking of trying it to aid against detonation on my nitrous set up .thanks
I was originally looking at that route with an nx stand alone but it was going to be a little pricey and I seen the meth kits were a little cheaper
Will the wet fogger work with lower fuel pressures like 10-15 psi I know I will need a lot bigger fuel jet, but will the nozzle flow fuel Properly
Ok cool I will go the stand alone route . I think I can save some $ buy building my own kit . Any one use a Holley blue or black for there stand alone ? I seen that they only max at 14 psi And I have a wet single nozzle kit do u think that will work as long as I re calculate my fuel jet for the lower pressure ?
Or I get a pump with more pressure and a regulater then I can fine tune my afr with the fuel pressure. Instead of moving jets one size or two
gavin2005
09-13-2015 09:04 PM
