nitrous outlet plate question
Will a 78mm nitrous outlet plate off of a fbody work on a silverado with a 5.3l ? I know the plate will fit but where the lines screw on the back of the plate is there enough room to do so with it on a truck intake?
Thanks in advance
Thanks in advance
no it wont, well not without getting it drilled for side inlets. I had that problem, but an easy fix. call dave, and he will drill it for you for side inlets for a small fee.
they moved the evap solenoid to use it. it is a tight fit too. but a 90mm plate for truck and car will have fittment issues too. I like the side inlet better. my first plate redrill was free, and it was $20 or so for the second.
