Nitrous Outlet Progressive Controller only 149.99
LS1TECH & TRUCK Sponsor
Introducing The Nitrous Outlet Digital Progressive controller for only 149.99.
The Nitrous Outlet's Progressive Contoller is an affordable, compact, and easy to use controller. It will easily fit into small spaces giving you more flexibility in install options. No computer is needed.
This controller has the following features.
Digital Hand Held Controller with LED read out for ease of programming and diagnosis, Conforms Vehicle RPM, Shows wide open throttle activation, shows gear lock out status, and shows activation status.
Can be used as a progressive controller only or use all controller features.
Adjust Start% and Build Time.
RPM activation and RPM deactivation.
TPS activation for falling signal, rising signals, low voltage signals, irregular signals and mechanical wide open throttle.
Multi Gear lock Out Feature allows delaying the stage from activation.
Ground & Hot Output wires allow multiple accessory activations for use with timing retards, indication lights etc.
Hi amp continuous duty circuits.
Reset option for clutch cars.
You can purchase this unit by clicking this link.
http://www.nitrousoutlet.com/catalog...3&product=4004
gavin2005
09-13-2015 09:04 PM
cheap, controler, controller, dave, daves, digital, nitro, nitrous, outlet, progressive, progressivre, wiki
