Nitrous tuning info...
Old 09-05-2013 | 11:20 PM
  #21
dirt track racer 81's Avatar
Originally Posted by n2oguy5
How did you know how to only lower fuel pressure? Why not jets?
Reading the plugs.. Porcelain was dark gray.. There is more fine tuning with pressure adjust than changing jets.
Old 09-06-2013 | 02:32 PM
  #22
n2oguy5's Avatar
How dark was it? Seems if the entire porcelain was dark grey, a jet change may have been needed. What does it look like now? Seems like that would require more than 'fine tuning'
How do you know what is too dark? Did you change timing at all?
Old 09-08-2013 | 08:22 PM
  #23
brandon6.0's Avatar
Dirt track racer knows what he is doing. Like the very first post by phantom. A perfect tune up is a clean white plug barely any fuel ring.
He is also running a low pressure setup. Just pulling out 1psi fuel pressure makes a pretty big diffeence in the jetting. Like with mine being high pressure it takes more like 5-10psi difference to get close or be exact.
Every nitrous setup is a lil different.
Old 09-08-2013 | 09:54 PM
  #24
skeet's Avatar
At Amarillo, thru out 3 passes I pulled out 1.5psi off the regulator to gains 3/10ths.. More adjustability changing pressure instead of jets.. I run holley blue with a low pressure regulator..
correct thus the reason i run a low pressure system now, its easier to fine tune the fuel PSI than swapping jets, not so easy with a high pressure system.
Old 10-03-2013 | 11:45 AM
  #25
MPFD's Avatar
11 Second Truck Club
Was that 1.5 psi on a 5 psi set up or on a 10 psi set up?
Old 10-03-2013 | 11:54 AM
  #26
On a 5psi set up.
Old 10-03-2013 | 12:15 PM
  #27
TXsilverado's Avatar
you're on a NOS crosshair, or crossbar right? i'm planning the same plate someday (if i ever finish my truck). i hear the NOS jet charts are pretty far off. how far from the fuel jet/psi did you guys deviate for the final tune?
Old 10-03-2013 | 01:07 PM
  #28
Yea it's a crossbar. I don't know off hand what jets Danny stuck on the fuel side..
Old 10-03-2013 | 01:19 PM
  #29
Phantom's Avatar
11 Second Club
Please don't pull 1.5 psi from 5 right off the bat and think you'll be ok. I suggest sending your stuff to Monty smith or induction solutions to have your setup flowed so you know what the tuneup should be
X_Racing1
21
03-30-2016 03:37 PM
southernsmoker
08-31-2015 04:09 PM
slowlsx
08-13-2015 09:28 PM
slowlsx
08-10-2015 06:33 PM
