Nitrous Usage
Old 10-17-2005, 10:34 PM
Destroyer of Transmissions
1SlowHoe's Avatar
Originally Posted by jimbob
The old general rule of thumb use to be...
100hp=1lb in 10seconds
so, say
200=2lbs in 10 seconds
50=.5lb in 10 seconds
500=5lbs in 10 seconds
so if you go 15 seconds just multiply 1.5 times your lb useage! A 200 shot would be 3lbs in 15 seconds useage....
So a 35 shot for 15 seconds would be
.3 5X 1.5 = .525
So 1/2 pound per run meaning I should get 15 solid hits out of a 10lb bottle? Plus 1 or 2 not so hard hits. Hows my math?
Old 10-17-2005, 10:39 PM
9 Second Club
Rhino79's Avatar
.3 5X 1.5 = .525
At least, actually 100 shot for 10 sec. = .8lbs usage.
Old 10-18-2005, 03:31 AM
11 Second Club
jimbob's Avatar
.3 5X 1.5 = .525
You, minds well through a 50 on there..Cory (Hummer guy) has had no problem now with some more runs and plenty of street use. The timing will not need to be reduced, we logged several runs and found no extra timing retard. You will want to watch that tranny though. When we upped the boost from 6.5-7 up to 8-8.5 the 4L65 tranny started to shift way to long into second. Luckily we have one of the best tranny builders in the US here and on our race team.
Oh and your math is close enough....
simman22
01-21-2017 10:27 PM
01silvy
09-26-2015 10:20 PM
gavin2005
09-13-2015 09:04 PM
gmcyukon
09-07-2015 08:46 PM
06murder
09-04-2015 03:54 PM
Quick Reply: Nitrous Usage
