Nnbs stupid juice...
#22
Haha what ever dude!!! I opened this up to read it and bam .. There it was .... Ha
We will run heads up on your nitrous tune and my truck will kill yours ... Heads up on nitrous tune with no spray this weekend lol .
#24
You are brave to put a 150-175 shot on a 6 cyl. It should hold it but much more then 100 on a 6 cyl isn't generally recommended.
As far as execution seems like it has been hit on the head.
A window switch is a very nice addition and a bottle heater is certainly a much better option then the torch.
#25
If you want a window switch, buy a progressive controller and have it all... Would be better with a controller but not at all needed
#26
150 shot divided by six cylinders v.s. 150 shot divided divided by eight cylinders.
You can do it. I've sprayed over 125 numerous times on a four cylinder, but what do I know? I'm the guy that uses a torch.
#27
Like CC05 said you are adding a good deal of power per cylender. You take a stock 6 cyl making 150-200 hp another 150 hp is a nearly doubling the power output.
Like I said it should hold, but you are pushing the limits.
Do you have a base line of what the truck runs now? That is what I would much more important then figuring how to put a 150 shot on the truck. My guess is that right now it maybe runs 17.5 and probably more like 18.0. Maybe I am way off but if you are lucky and it is running 16.5 a 150 shot is going to maybe get you running 15 flat. Why the hell would you risk blowing you engine to run a 15.0?
#28
We out it on the rollers at my stepdads work. Stock besides 3" exhaust. Put down 236.xx at the 285's. Btw he works for redbull racing(NASCAR). We were all pretty impressed. Remote bottle opener worth it?
#29
Yes a remote bottle opener is worth it.
I am telling you run it down the strip. You won't outrun a stock tunner car if you are going to make a 15 flat. That sure would be embarrassing to say you have a 150 shot and loose every race you run. Maybe I am wrong but I would be amazed if it runs better then 16.5 and it is probably slower then that.
Gmc_sierra
09-13-2015 10:02 PM
