simple 100hp dry shot nitrous setup for Silverado
Does anyone have a picture of their installed dry nitrous setup?
I'm not sure how to handle the fuel lines on my return system, so a dry setup seems to be the best way to get 100+ hp without having to make any serious adjustments.
Thx,
Dave
Thx,
Dave
you should have a fuel pressure test port on the passenger side of the motor just underneath the cover on top of the intake manifold. all you have to do is remove the schraeder (spelling) valve and voila you have a fuel source. if you still wanna go dry i would recommend looking at the sponsors on the right. i think its nitrous outlet that has the distribution ring that goes right into your cone filter if you have a CAI. thats about as simple as it gets.
Baltimore Whore
You can't miss it. It is right on the rail, on the pass side. It has alil cap, looks like a valve stem, when ya take the cap off
I have my FP gauge line hooked up there..
John
John
The Braided line should screw right on to the test port. Make sure you have a rag over it when you take the valve out... youll get a little spray for a second.
the rpm window is a good investment for a stock tranny. Also keeps from over rev. Best bet is to piece together a used kit. Id sell you mine, but I like it. Get a Nitrous plate, and a fuel pressure safety switch. Or a A/f ratio safety switch from dynotune. Any bottle will do. I recommend NANO Nitrous assist. Make sure you get a wideband. And at least some tr-6 plugs.
IMO a wet 100 shot hits harder than a dry 100 shot. Also, I thought that the only thing you can do with the tow/haul button is change the shift points.
