Spark Plugs for nitrous install.
Old 05-13-2010, 05:23 PM
slowec's Avatar
Originally Posted by 00buckshot
Rodney, on the Br7ef's, are those an NGK plug, because I've always run tr6's, you think I need to upgrade?
People who are WAAYYY more knowledgeable than myself absolutely reccomend the br7ef's for anything bigger than a 125 shot!.. They are ngk's and are one step colder than tr6's and are not protruded (which makes them less likely to glow red and blow your junk or detonate).
This is good advice! call any N20 company and ask them.
Old 05-13-2010, 09:20 PM
05RST2NV's Avatar
Originally Posted by slowec
Did you log the fuel pressure or is this your assumption. Most run a 150 on a stock pump with no problem , however NOBODY should spray a 150 on stock plugs. People give me crap about hitting a 75 on tr55 (stock heat range)! Seems to be a lot of N2o myths being stated in this thread. Please do your research guys. Blowing an engine is no fun.
No fuel pressure log.., but i was running nitrous on trucks to cars to drag bikes when most were still in diapers so yeah it went lean.. The 11 sec single cab in my sig was on 200 shot, WITH the right plugs and i didnt have a problem. In this case i wanted to run at the track and did not feel like swapping plugs, and this is what happen and i just wanted to show what will and can happen when running stock plugs..
Old 05-13-2010, 09:57 PM
11 Second Truck Club
fastrt's Avatar
I run tr6's now, but in a few weeks with higher compression, I think I will find me some br6ef's. where is the best place to get them price wise?
Old 05-14-2010, 06:40 AM
05RST2NV's Avatar
Does NGK make the br6ef's as well?
Old 05-14-2010, 07:00 AM
slowec's Avatar
yes NGK makes those, good for 125 and smaller shots. can be had at any parts house, just have to order them.
Old 05-14-2010, 07:43 AM
05RST2NV's Avatar
Cool thanks
Old 05-14-2010, 08:26 AM
Wearin' da big hat
00ChevyScott's Avatar
NGK stock number for BR6EF is 3177. That is the part number you will need to ask for at just about any parts place.
BR7EF is 3346
twake_410
04-14-2016 09:58 PM
00loudchevy
12-03-2015 05:54 PM
bearden86
26
11-15-2015 03:58 PM
02AWDAWSDenali
10-01-2015 05:08 PM
KleanKustoms
09-30-2015 05:07 PM
Quick Reply: Spark Plugs for nitrous install.
