standalone fuel system for N2O
Truck Sponsor
The stand alone tank is a good idea for any wet kit. It allows you to run HI octane fuel while spraying nitrous and reg. fuel when not. The standalone helps you keep you standard fuel system intact and no need for larger pump or dual pumps. Depending on the amount you are spraying.
Let me know if I can help in any way.
Here a link on several tanks we have done in the past.
Truck Sponsor
The system is wired into your arming switch. This keeps the pump OFF until you are ready to use it. I would recommend installing a fuel saftey switch for added security. If you loose pressure or the pump fails the system will not work with a FPSS in place.
. You would never want a fuel system to start working at WOT by then its tool late.
. Cost on this system un polished is 700.00
. 2 stages no problem you just need a Y or T fitting and some more line.
Both stages will need to be ran jetting at the same PSI. And it is recommended you tune one stage in first then the second stage. depending on how you are running your stages will dictate how you should tune your system.
