Switch set-up or panels?
Old 01-16-2006 | 07:27 PM
Default Switch set-up or panels?
Hey i was wondering how you guys had your switch panels or set-ups (pictures if possible) and how you organized everyting- since im getting a bottle warmer i will have 3 switch (purge/arm/warmer) and then later a opener so how do you guys do it?
Old 01-16-2006 | 07:32 PM
thunder550's Avatar
High on diesel fumes
Mine switches are not for nitrous, but there's a nice spot below the cigarette lighter / accessory plug place for some toggle switches. I have five of them here now.
Old 01-18-2006 | 07:57 PM
nightrunner's Avatar
Mr. Obvious
heard of the arm in place of the tow/haul switch
Old 01-18-2006 | 07:59 PM
Mr. Obvious
if you dont have 4wd or trac control, you can put it above the headlight switch
Old 01-18-2006 | 09:00 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I am making a plexi glass plate to go in my center console where it starrts to go up to the bottom of the dash where it has slots for cds Im goign to put all my switches for my wideband, purge, arm, heater, remote bottle opener, electric cutouts, auxilirary lights and an extra for room to grow. Ill post up a pic of it when Im done it will be a week or so till Im done.
Old 01-18-2006 | 09:16 PM
Wilde Racing's Avatar
How do I change this text
I have mine here, not for nitrous, but same thing. and yes I need to re-adjust the thrid one over.
Old 01-19-2006 | 12:13 PM
86MC_SS's Avatar
I like this control panel best I plan on buying this.
Old 01-19-2006 | 12:33 PM
white1's Avatar
Thats sweet I like that
Old 01-19-2006 | 01:39 PM
slowprocess's Avatar
I put mine in the cargo lamp and fog light switch holes. My trenz cover doesn't let the cargo light flash bright, and I took off those crappy gm foglights, so I just had the buttons their taking up space. The bottom one does the heater and the top does the activation switch. I'm still trying to decide on my purge location though.
Old 01-19-2006 | 04:02 PM
BigKID's Avatar
I currently just have two lighted rocker switches (heater/arm) in the blank panel by the pass airbag switch. I am in the process of making another panel with some nicer switchs that will look almost factory. I will be adding a few more switches in the process.
Quick Reply: Switch set-up or panels?
