Tps Issues with Dr.X Harness?
Anyone have problems with fading throttle position with the Dr. x Adapter harness to run a 90mm TB? Seems like my fjo controller gets a weak signal or something just curious if anyone has had any issues, Truck runs great though, just gets a surge on the kit every once in a while and if you back out of the throttle and get back in it cleans up and gets back in the power.
See thats whats weird, Wiring is fine... the way the truck acts is like the blade is closing slowly but the truck still sees wot, It kind of just fades the power then you lift and get back in and the power is back, But in the same amount of time as before (bout 1.5 secs) it starts to nose over again and you have to lift and get back in... Odd one because if the truck was not seeing wot it would turn off the kit... This issue here just kinda "fades" the kit
took the progression out... not sure if its nitrous or engine its just fading period, This issue is dead nuts consistant every time... Here listen
http://www.youtube.com/watch?v=EUkZwNWEGE8
That pass is a 10.96 at 130 and it has so much more in it if it would run on through, I have tried different bottles and everything. It's fine on the dyno cause its not long enough for it to happen...... Its a gremlin
