Wet or dry nitrous?
13 Second Truck Club
The wetter the better.
Truck Sponsor
I personally like dry shots,nothing wrong with them at all,just has to be done in alittle different way as far as tuning and must have injectors to support your application and the amount of nitrous you plan to spray.
I personally have a wet but have done dry many times,I like them both
I agree as well. As Charlie can attest to, there are a few tricks you can do in the tune to pull timing when a dry shot is applied through the MAF. I like knowing that my tune is set-up in a way that I can run an aggressive N/A tune or just kick on the switch and spray a dry shot without a reflash. I also like the fact that dry is "generally" safer than a wet in regards to an intake backfire. For whatever it is worth, I have both a wet (DP system) and a dry kit on my truck.
FormerVendor
Nick
