Wet or dry nitrous?
I was in the same position as you. I went with a wet plate kit and after talking with HSW I am going with their Micro Edge+ and accesory kit + a stand alone fuel cell for it(laugh if u want). It's all about what you want it to do. Have a safe setup. The guys here helped me choose my setup thats going to be installed next month.
Truck Sponsor
You know how it is on the streets,once it is spread it sticks.LOL
I never really touch my fuel jet,If I want I will just add more fuel via the injectors in the programming.I have something setup where I flip m arming switch and spark is pulled,therefor I can add fuel in the PE>Adder vs IAT.I like this way.
This along with the Microedge makes a pretty neat nitrous setup.
In my opinion, either wet or dry nitrous is great. Both require tuning but the dry kit requires larger injectors and fuel pump. I have tried both and I like running dry kits. They are simple and easy to install and can be "hidden". I also like dry shots due to "tricking" the computer to pull timing and add fuel. I also had all of my dry nitrous tuning done on the dyno though. Some people don't like that idea but I never had a problem....just keep the shot reasonable and have a spot on tune!!!!!
Get a harris speed works wet plate kit. Buy beg borrow or steal a wideband and use the large n2o jet (62 I think)and a 33 instead of a 35 for fuel. They run too fat how they jet them. Stock pump will support a 150 shot. Use the wideband to verify your a/f ratio is richer than 12.5 to 1 and you should be thrilled with the results!
gavin2005
09-13-2015 09:04 PM
06murder
09-04-2015 03:54 PM
