what needed to run 300 shot
Originally Posted by Pewter53
then you should have no problem spraying that little of a shot just keep tabs on the a/f keep it real rich and keep your fuel pressure on the rails around 68 for that big of a shot lol these things need no girdles they have 6 bolt mains they are made to run 6600 rpm all day everyday in boat applications. they love nitrous i promise the more the merry is how i look at it you will have a very big grin on your face wehn you get the second stage kicked in. i would go with a 175 out the whole cause that is going to be a hell of a launch trust me on that one to i do it every weekend. and the next 175 shot about the 60 foot and you should be very happy and safe.
1 Post
just keep the fuel pressure when you go to spray don't this on motor alone keep it at bout 68 no more though and keep your fuel trims since i am guess you have a tuner hopefully keep them very rich from about 2800 to where ever you plan on spraying around 6000 or so on that kind of shot.
1 Post
the reason i am saying running that much is because just because you are using a wet kit it is going to be pulling out of the fuel rail if you do not use a external n2o fuel system . if i was you i would have a go cart gas tank the little gallon ones mounted somewhere under the hood or in the back with atleast 114 octane gas as your n2o fuel supply pulling off the rails with that big of a shot id really going to be pushing it.jegs has them for around $100 i think i really think you should get some et streets or atleast some nittos what kind of tire do you plan on running. street tires are never going to hold that kind of shot i have some pretty sticky tires and my 175 shot and stall make me get sideways for atleast 75 feet from a 60 mph roll. its really cool to ride it out when your racing from a roll people will be scared to race again.
I had seen the stand alone systemsand had wonderd about them. and i dont think i'll have traction issues i plan to run some 245 or 265 truck tires put it in 4hi and go didn't seem parish had alot of traction issues so i dont think i will.
