Window Switch and Sneaky setups?
Old 11-09-2006, 01:59 PM
MOOBIES Moderator
Scream's Avatar
Originally Posted by nightrunner
a 3-piece escalade engine cover would hide everything real nice or put everything in wire loom
I had a setup like this back in the day...was REALLY sneaky. I ended up taking the kit off before I could get it working, but I had the nozzle coming in at the bottom of the throttle body, wrapped in wire loom.
I am beddy beddy sneaky sir! :lol
Old 11-09-2006, 03:33 PM
TXsilverado's Avatar
Originally Posted by slowprocess
Yeah, I'm going through the egr port. I'll get some pics with the covers off when the truck gets back in my possession. I have the noids mounted using the passenger side fuel rail, and they fit perfectly under the side cover. Also, my switches for my bottle warmer and activation are my fog light and cargo lamp switches. It's a hard *** setup to spot and impossible to see at night on the street.
thats exactly what im going for. bottle under the bed on the frame rail, all switches inside of my console under the cup tray(very sneaky spot ), wot switch under gas peddle, and everything under a 3 piece cover plugged into the egr port.
are you using a freeze plug, or the factory plug for the egr?
Old 11-09-2006, 07:41 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
GM makes a plastic block off piece that you can tap for the nozzle. Check out my thread from a long time ago for where I mounted my WOT switch under the dash.
Old 11-09-2006, 11:10 PM
i have the gm blockoff plate...its not plastic.
Corvette454l88
09-01-2016 01:24 AM
atxlt
07-20-2015 11:06 PM
Offroadunleashed
07-20-2015 02:25 PM
Quick Reply: Window Switch and Sneaky setups?
