WOT Switch Mounting
#21
Former Vendor
Originally Posted by Z06 DREAMING
Ricky, where would a guy get a TPS for substitute of a WOT swithch? And how is that installed?
there are 4 wires
1) hot input from toggle
1) hot output to relay red wire or 86 pin
1) ground good engine ground, not were your noids are grounded.
1 tps sensing wire. I believe blue wire on the tps, you would need to check this one with a multi meter..
Ricky
#25
heres some pics of my mico switch setup on the throttle body if you still have'nt mounted it yet, it requires a little bit of bending but works perfectly sorry for the last image being blurry[IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
#26
Another reason I like the wot sw mounted under throttle pedal, is the fact it is much cleaner. I don't want the extra stuff under my hood, it isn't like the sw and brkt and wiring are a trick good looking hi-per part.
Robert
Robert
drummer0415
11
10-24-2015 08:16 PM
Tydriver
45
10-23-2015 09:19 PM
Brandonlflr12
14
09-16-2015 12:44 AM
jtphelps289
09-01-2015 08:58 PM
