Bullydog Powerhound
Bullydog Powerhound
2003 6.0 PSD.
I got my hands on a Bully Dog Power hound for a 2003 PSD.
Is this a good Module?
What numbers should it be good for?
Thanks guys!
Thanks guys!
installed the BD PH and from a stand still the truck is just a tank... once it gets moving, well it does seem to move on out pretty good. Goin to race when i get my truck up and running again.
ive tried a few times.... When i try to brake stall it to build boost, its still a Pig off the line till bout 30mph. Our 03 F-350 is the same way... build as much boost as the brakes will hold and just hammer down.... Its almost if you could count to 4 or 5 before she starts Moving. From 30-70ish is better, but its just one of those things.
Need More N2O Mod
thats odd, every turbo diesel i have drove you can spool the turbo up to 25+psi and as long as your holding the brakes it wont move. Its not good for the tranny but it can be done a few times. In my 06 i can launch it on a 30psi boost and you better hang on.
60, bully, bullydog, dog, f250, ford, forum, hound, install, installation, instructions, power, powerhound, problems, psd
