{Project} White Noise- 2005 ECSB 2wd Silverado, Forged 402/4l80e/PTE 88mm turbo
#92
This works as I have mine set up like that but I really hate it for tuning. Yea, lambda 1 shows on the wideband in closed loop but I always wonder what is actually happening in each cylinder. I always feel like one bank is actually pretty lean, while the other bank is equally as rich. So fueling is only correct in all cylinders at WOT. But that is just how I think about it, don't know if its true or not.
#93
#94
Yes, but can you actually do anything about a bank leaner than the other? I can see it for diagnosing something but I'm not sure if I've seen anything in HPTuners about specific fueling like that.
Started on the down pipe tonight. It's fitting way better than I expected. I am kind if hung up right now because I forgot to order some 4" v bands.
A/C clearance
A/C clearance
#100
Yeah, you have to wrench it with your hand pretty hard to unlock it. There are threads like the cap, but a lot of notches to get past as you loosen it. That's why it doesn't turn when you pull the cap. Just unscrew it, took me a little to figure it out.
