03 RCSB Build
#21
You’re not helping….
Have a very similar setup now other than I went with TSR anti-roll bar and a fabricated set of front spring brackets as I had Belltech that had this thing slammed even with a the notch. Had to send my Recklez back as it turns out I have an early 99 frame that is different and it did not fit well at, would have had to cut it apart to work. Switched to Castle Manufacturing notch which fit like a glove.
Terdstang (04-12-2024)
#22
@ALL ULL C Interesting about the 99 frame. I also have a 99 frame that I've been told has a different "look" in the front half of the frame...
#23
#24
I should have known something else would come up, another fun project was the body mounts. That took 3 tries only to ultimately opening up the mounting hole to accept the normal mounts. But yeah, it is definitely different from the rail seam just ahead of the axle back.
I’ve been saving pics here and there as we should be close to wrapping it up, the FH lower billet shock brackets show up Monday so that’ll be the last piece.
wretched73 (06-06-2024)
Miller boost
01-06-2016 07:59 PM
