03 SS awd turbo street build
Old 04-22-2018 | 10:39 AM
  #171
SDjeff619's Avatar
The codes it’s throwing when going into REP
Old 04-24-2018 | 09:22 PM
  #172
SDjeff619's Avatar
Here it is, first start up and moving on it’s own power since Dec 2016.
Old 04-24-2018 | 10:53 PM
  #173
FFDP's Avatar
P0102 is normal if the MAF is gone. P0103 should also be present if the MAF is failed correctly in the calibration for speed density.
P0106 is not normal, check wiring if you hadn't yet. Verify it's pinned right for whatever MAP you used.
Evap stuff can just be disabled if you removed those parts.
P1514 likely will require you to raise that table or max it out so it never happens, fairly common on boosted setups.
Old 04-24-2018 | 11:03 PM
  #174
Vortec350ss's Avatar
What he said. Check your logs for MAP activity that seems normal. That is definitely what caused your REP issue. The other codes are normal. You should be able to get all those readiness tests to pass by disabling codes.
Old 04-25-2018 | 02:38 AM
  #175
01FormulaTA's Avatar
Center Caps turned out great!..one of the cleanest trucks on this site..cant wait to see some WOT vids....what kind of power are you expecting from this combo?
Old 04-25-2018 | 08:02 AM
  #176
SDjeff619's Avatar
FFDP, Vortec, thanks for the info on the codes. Atomic is tuning the truck and fixed them. I have no clue when it comes to tuning and with HP tuners for that matter. Down the road I plan to spend the time on HPtuners forums and learn but for now I need this truck running.
Formula, thank you. I originally had 800+awhp in mind but I really have no idea what to expect. This is my first real LS build. I’m sure this thing is going to be fun on the street.
Old 04-25-2018 | 09:14 AM
  #177
baddbradd's Avatar
Beautiful craftsmanship
Old 04-25-2018 | 03:56 PM
  #178
BudRacing's Avatar
Looks awesome. Those wheels are perfect. You may want to reach out to Cosmis to see if they'd be willing to send someone to do a photo shoot with your truck for their marketing.
Old 04-25-2018 | 06:09 PM
  #179
SDjeff619's Avatar
Thank you Badbrad.
Bud, that’s not a bad idea. In a week or two the truck is going to the paint shop for a respray of the bumper, grills, Hood, roof, 3 piecebed rail/spoiler and mirror caps. They are going to also cut and buff the side panels. Then it will be photo shoot worthy.
Old 04-26-2018 | 08:17 AM
  #180
kaze_v8's Avatar
That thing is so sweet, really tempting me to want to get another SS.
