03 SS awd turbo street build
Old 10-06-2018 | 08:19 PM
  #241
SDjeff619's Avatar
So I started hearing a squeal at low speeds 5-25 mph. I thought it was the t-case that I rebuilt. I pulled the t-case and turned the “Built” 4l80e to hear this. Anyone heard this before? Only 3k miles on the build. I’m calling Hughes Transmission on Monday!
Old 10-06-2018 | 08:51 PM
  #242
1FastBrick's Avatar
Custm2500's Rude Friend
Sounds normal to me. It only spins 1 way correct?
Old 10-06-2018 | 10:02 PM
  #243
SDjeff619's Avatar
yes one way...after your comment, I thought to turn a donor 4l80 I have in the garage and yes it sounds identical. Thanks for pointing that out. Im new to the auto trans game. Time to tear open the T-case.
Old 10-24-2018 | 11:42 PM
  #244
SDjeff619's Avatar
While chasing this squeaking noise I pulled the transfer case. Tore it down to find that 135k miles took its toll on the main shaft splines that come in contact with the input shaft stub. They were damn near knife edged. The rear housing that holds the output shaft bearing was worn enough to move around freely and the rear housing output bushing was toast which also started to work on the drive shaft yoke.
Old 10-25-2018 | 06:22 AM
  #245
ILuvJDM's Avatar
Every bit if work you do is so clean, looks great
Old 10-25-2018 | 07:16 AM
  #246
Choda's Avatar
wow, thats a beaut
Old 10-25-2018 | 07:26 AM
  #247
03sierraslt's Avatar
Looks good. Is that Merchant Auto pump actually the 246 pump? I think they are the same.
Old 10-25-2018 | 08:48 AM
  #248
SDjeff619's Avatar
Thank you gentlemen.
Yes, I used the merchant auto pump cover. the pumps are all the same part number. Most of the parts in the 149 are the same as the 246 and others. However, one difference I came across is that on the 246, 261, and 263 they output shaft bearing and reluctor wheel slide on and off by hand with is. The 149 needed to be pressed on and pulled off, and the reluctor wheel is different. I damaged mine pulling it off but the replacement was only $20...even though I’m not even using the speed sensor in the t-case since the 4l80 swap.
I also got time to finish fabbing up the rest of the exhaust with the Borla xr1 and QTP 4” cutout.
Old 10-25-2018 | 12:14 PM
  #249
Atomic's Avatar
I have a gauge for that
That is the cleanest transfer case I have ever seen
Old 10-25-2018 | 05:15 PM
  #250
SDjeff619's Avatar
The cast aluminum **** can came out nice but we shall see if it will last.
