1963 Scout 80 Resto mod
Oh! This is going to be cool.
This morning I took a piece of my seats and the carpet sample up to the paint store.
After about 40 mins of going through color books I came up with these two colors.
Theyre not exact matches, so I will have to spray a bigger panel of the colors on lets say an 10 inch by 20 inch piece to see if the variance is noticeable or not.
wretched73 (06-28-2024)
Engine dilemmas.
Have a great running 5.3 with higher compression and big cam, makes decent power being NA.
-would have to tear it down gap rings and swap in another cam
-high compression
OR
I have 2 bone stock 'LS' engines.. another 5.3 (gen 3) or a 4.8 (gen 4)
-tear down gap rings
-install correct cam for boost
-5.3 is bigger but weaker rods
-4.8 is smaller but stronger for boost
have 706, 862, 243 heads that need rebuild as well
about 10 psi for daily driving, but might turn it up when needed
Decisions, decisions...
-high compression
OR
Make a high rpm motor out of the 4.8 and boost it.
Probably 4.8
Sell those 862s yucky. Gross old LS tech
Fair nuff
shakenfake (07-14-2024)
The ididit steering column arrived
The gauges are here
The hydroboost unit is here
The wire harness is here
-possibly going to run an aluminum driveshaft, but need to see the specs if it'll hold up to what we are planning
The gauges are here
wretched73 (07-18-2024)
