1984 K5 Blazer
#132
I've decided that it'll just be easier to burn the truck to the ground and redo it from the bare frame than fight this rear end. Spent 2.5hrs today and still can't get one leaf spring in. Whole rear end is cockeyed. Kids across the street learned some new words today. Broke a ratchet strap trying to compress the u-bolts to fit. I can either get the front leaf spring bolt in or the rear but not both. **** this rear end.
dantheman1540 (04-23-2020)
#136
Sending a virtual high five.
Bgbldodge (04-23-2020)
#137
Got the passenger rear finished up today.
Upper shock mount on the driver side. Wonder how long it's been loose?
Found out why the drivers driver's side was crooked. Center pin was sheared off. Both spring perches were completely caked in mud. Picture was taken after cleaning it all out.
Driver side spring is bolted into the front spring mount and the axle. Shock and brace are completed. Once the bushings arrive I'll get that installed and get the rear end back on the ground and then knock out the front shock mounts and call this project done.
tjmath (04-25-2020)
#138
Transmission mount spacer.
Previous owner never put a washer behind the bolt head so it nearly pulled through the frame.
Got it pulled back up nice and tight with flat washers on both sides and lock washers.
#139
Slightly off center.
But it didn't matter because **** you truck.
I need to go drive the thing as it's still sitting at the same hub to fender measurement it was before (~30"). Side effect of torquing everything with no weight on it. But that'll wait until after I put the front shocks on and figure out the drag link.
tjmath (04-27-2020)
