1984 K5 Blazer
Old 04-21-2020, 03:24 PM
  #131
Bgbldodge's Avatar
I've got gloves. Multiple kinds. This was just that one time I didn't.
Old 04-21-2020, 05:44 PM
  #132
Bgbldodge's Avatar
I've decided that it'll just be easier to burn the truck to the ground and redo it from the bare frame than fight this rear end. Spent 2.5hrs today and still can't get one leaf spring in. Whole rear end is cockeyed. Kids across the street learned some new words today. Broke a ratchet strap trying to compress the u-bolts to fit. I can either get the front leaf spring bolt in or the rear but not both. **** this rear end.
Old 04-21-2020, 06:07 PM
  #133
Bgbldodge's Avatar
Haha success!!!! Got one leaf spring bolted in. Now to make the u-bolts my bitch.
Old 04-22-2020, 05:37 PM
  #134
Bgbldodge's Avatar
Wife has a virtual happy hour and I've gotta watch the kids. Work must go on.
Old 04-22-2020, 06:10 PM
  #135
Bgbldodge's Avatar
I win!!!! Scary part is the axle shifted nearly an inch to the driver side as I was tightening it down. I'm sure the other side will go in nice and easy.
dantheman1540 (04-23-2020)
Old 04-23-2020, 03:25 PM
  #136
tjmath's Avatar
Sending a virtual high five.
Bgbldodge (04-23-2020)
Old 04-24-2020, 07:51 PM
  #137
Bgbldodge's Avatar
Got the passenger rear finished up today.
Upper shock mount on the driver side. Wonder how long it's been loose?
Found out why the drivers driver's side was crooked. Center pin was sheared off. Both spring perches were completely caked in mud. Picture was taken after cleaning it all out.
Driver side spring is bolted into the front spring mount and the axle. Shock and brace are completed. Once the bushings arrive I'll get that installed and get the rear end back on the ground and then knock out the front shock mounts and call this project done.
tjmath (04-25-2020)
Old 04-25-2020, 04:30 PM
  #138
Bgbldodge's Avatar
Transmission mount spacer.
Previous owner never put a washer behind the bolt head so it nearly pulled through the frame.
Got it pulled back up nice and tight with flat washers on both sides and lock washers.
Old 04-27-2020, 05:45 PM
  #139
Bgbldodge's Avatar
Slightly off center.
But it didn't matter because **** you truck.
I need to go drive the thing as it's still sitting at the same hub to fender measurement it was before (~30"). Side effect of torquing everything with no weight on it. But that'll wait until after I put the front shocks on and figure out the drag link.
tjmath (04-27-2020)
Old 04-30-2020, 08:26 PM
  #140
Bgbldodge's Avatar
Anyone know a good axle shop around Georgetown//Austin, TX? Looking to get 4.88s and a rear locker installed.
Quick Reply: 1984 K5 Blazer
