1984 K5 Blazer
The following 2 users liked this post by Bgbldodge:
arthursc2 (11-20-2020),
dantheman1540 (11-20-2020)
tjmath (11-21-2020)
#274
Don't think it needs to be pretty to work for that truck tbh.
Should work out perfect for what you need and that's more important anyway.
#275
Well it worked great. No more tire rub. One of the wheels did get scarred up on a rock on the last trail but it made it home. 70mph the whole way and got 14mpg. Had a great time. Not a lot of pictures. Other truck I was wheeling with was on a 7” lift with a 3” body lift and 40’s. I’ve never felt small until today. Lockers would have made the last obstacle a cake walk. I had to throttle it hard and bounce it up. Couple of the guys didn’t know how I didn’t break anything.
dantheman1540 (11-23-2020)
#276
Prob didn't have enough power or torque multiplication to break anything 😂 you must drive a Toyota (is what those guys are thinking)
that wheel is mint! Didn't knock the weight or the valve stem off! ****** is brand new to crawler bois 🤘🏻 You can get weld in rash rings if you want to add some bead support. You can also do the DIY beadlocks. Get rash rings, ~1" wider width and can play at 5-6psi if you so desire 😉
#277
Except I don’t want to make this a full time crawler haha.
It was funny, the guy I was wheeling with, his truck is sitting on dually axles front and rear which makes it 7-8” wider than mine but he did it so the front hub would be protected as it is sunk flush to the wheel. Told him I hadn’t had any worry about it yet. And then I go and do that on my wheel haha. Little sand paper and some paint and it’ll look brand new again.
The following 3 users liked this post by arthursc2:
