1984 K5 Blazer
Old 05-17-2022, 05:48 PM
  #511
Bgbldodge's Avatar
Decided to throw my weight behind a presidential candidate.
And because Letterkenny.
The following 2 users liked this post by Bgbldodge:
Modern Barbarian (05-23-2022), wretched73 (05-17-2022)
Old 05-18-2022, 08:25 AM
  #512
shakenfake's Avatar
Received 1,276 Likes on 973 Posts
Would have been great with a Reagan Bush '84 sticker
arthursc2 (05-22-2022)
Old 05-22-2022, 10:36 AM
  #513
Bgbldodge's Avatar
Got the old gas tank out and found some more west Texas. Now to pressure wash the entire under carriage, remove the body lift and install new bushings, and finally get it pushed into the shop.
Old 05-22-2022, 05:28 PM
  #514
Bgbldodge's Avatar
Truck actually cleaned up pretty good from a pressure washing.
Old 05-23-2022, 12:54 PM
  #515
arthursc2's Avatar
Received 1,496 Likes on 1,097 Posts
Jesus that thing is TALL
Old 05-23-2022, 12:58 PM
  #516
Bgbldodge's Avatar
Ya it is. That’s why I need to yank the body lift. 3” body lift makes a bigger difference than you realize. Otherwise it’s the same springs and tires from my last one.
Old 05-23-2022, 01:09 PM
  #517
arthursc2's Avatar
Will it be able to cycle the 37s (no cutting) if you take out the body lift or doesn't matter because it's trail days won't be as rough as the white one?
Old 05-23-2022, 04:59 PM
  #518
Bgbldodge's Avatar
I’ll have to chop the front fang off and trim the back of the fender about an inch but that’s about it. The way I’ll do it you’ll never know it’s not factory. Not like the sawzall work the PO did on the white one. I prefer the low lift big tire look but also the lower center of gravity and ability to stick it in the shop.
arthursc2 (05-23-2022), wretched73 (05-24-2022)
Old 05-24-2022, 07:07 AM
  #519
wretched73's Avatar
I'm a big fan of a stuffed tire over seeing the entire wheel well
Old 05-24-2022, 07:35 AM
  #520
Bgbldodge's Avatar
Same here. If I could get away with less than a 4" lift I would but I'm already dangerously close to smashing my oil pan as it is with the crossover steering.
Quick Reply: 1984 K5 Blazer
