1984 K5 Blazer
Old 08-04-2022, 12:21 PM
  #531
Modern Barbarian's Avatar
Gnarly. you just gonna scrap it or try and clean it up and sell it? Might could make a few bucks back to put into your project.
Old 08-04-2022, 01:07 PM
  #532
Bgbldodge's Avatar
Scrap it. Don't have the space to store an engine that I won't need or use. No one wants a sbc anymore so you get pennies on the dollar. My running 350 I sold from my last one was only able to get $400. A non running needing a rebuild engine would be lucky to get $100 and more than likely $50. Not worth the hassle of trying to sell it.
Old 08-05-2022, 07:15 AM
  #533
zz454Chevelle67's Avatar
Love those old Blazers.
Bgbldodge (08-05-2022)
Old 08-05-2022, 11:53 AM
  #534
Bgbldodge's Avatar
And it’s out. Now to strip the accessory brackets off of it, separate the t-case and trans, and haul it off. Going to keep the t-case as it’s an np208 like I currently have so a spare wouldn’t be a bad idea.
Old 08-11-2022, 10:28 AM
  #535
Bgbldodge's Avatar
700r4. Might need a rebuild. Worked when I bought it. No low ballers. I know what I got.
It’s going to the scrap yard tomorrow. Just draining fluid from it and found this and chuckled.
Modern Barbarian (08-11-2022)
Old 08-12-2022, 11:59 AM
  #536
Bgbldodge's Avatar
Hopefully get enough to cover the gas driving to the scrap yard.
Old 08-12-2022, 12:15 PM
  #537
at todays gas prices?
Old 08-12-2022, 12:36 PM
  #538
Bgbldodge's Avatar
Haha. Thankfully the scrap yard is about 5 miles away. 880lbs of scrap got me $72. Worth it. Now to pressure wash the truck again now that the old crap is out of the way and get work on installing the new engine and transmission!! I’m hoping by next Friday I’ve got the 383//4L80e//np208 bolted in the truck. Only thing I really need to figure out is the transmission crossmember and the bushing for it but that’s pretty simple.
Modern Barbarian (08-12-2022)
Old 08-15-2022, 02:59 PM
  #539
Bgbldodge's Avatar
3 days left of summer and my daughter said she was bored. She got put on clean up duty. Got the garage cleaned up and her and I pressure washed the engine bay and under carriage again now that the drivetrain is out of the way. Need to pick up bolts for the converter and bell housing and a transmission mount but the plan is to have the new drivetrain bolted in end of this week.
zz454Chevelle67 (08-16-2022)
Old 08-17-2022, 11:54 AM
  #540
Bgbldodge's Avatar
In like Flynn. Now to buy flex plate bolts, converter bolts, bell housing bolts, starter bolts, starter, water pump, fans, gas tank, sending unit, fuel line, trans cooler lines, trans cooler fittings, vss sensors, shifter, radiator, radiator hoses, air filter, valve cover spreaders, valve cover bolts, thermostat, thermostat housing, spark plugs, transmission mount, redo both driveshafts, hook up brake lines, commence wiring, and then maybe by Christmas try to start it.
The following 2 users liked this post by Bgbldodge:
RedXray (08-18-2022), zz454Chevelle67 (08-18-2022)
Quick Reply: 1984 K5 Blazer
