1984 K5 Blazer
Old 10-05-2022, 07:57 PM
  #551
Bgbldodge's Avatar
Body mounts are already loose. I replaced them when I got rid of the body lift and haven’t tightened them back up. I’ve got some 3” wide ratchet straps we use for hauling hay that I’ll put on there tomorrow and try to suck everything in.
RedXray (10-05-2022)
Old 10-07-2022, 04:40 PM
  #552
makes children cry
_zebra's Avatar
i know with the NV3500 -> nv4500 swap, the stock crossmember just had to rotate 180° (left side on the right) to bolt up like stock.
Old 10-11-2022, 02:51 PM
  #553
Bgbldodge's Avatar
Got the frame pulled in and mount installed. It’s kinda scary how easily the frame bends with a pair of ratchet straps. You can see how far back the whole mount had to slide. I went to put the t-case in and either I didn’t have it clocked right or I’m gonna have to run a 1” body lift to clear it which I really don’t wanna do. Floor might just need some loving from a sledge.
RedXray (10-11-2022)
Old 10-19-2022, 12:52 PM
  #554
Bgbldodge's Avatar
Few love taps from a sledge to the floor and she fit like a glove.
Yes, that is what she said.
Driveshafts are going to fit good enough for the time being. Still want to have them cut and lengthened accordingly but to get on the road they will be fine.
Old 10-26-2022, 12:07 PM
  #555
Bgbldodge's Avatar
Did a few small things. Installed the injectors. Installed the battery box. Started laying out the fuel injection harness. Took inventory of what sensors and adaptors I need to order. Trying to find a place to put the coil and FPR. ECU and MSD will go in the cab under the dash.
The following 2 users liked this post by Bgbldodge:
The_W (12-06-2022), zz454Chevelle67 (10-28-2022)
Old 12-06-2022, 02:26 PM
  #556
Bgbldodge's Avatar
Not a real exciting update but making progress. Got the valve covers bolted on. Reordered header bolts 3 times cause I can’t read a tape measure but those will go on tomorrow or next day. Torque converter is bolted to the flex plate.
While researching mounting spots for the Holley ECU I stumbled across the factory build sheet.
ECU is going to fit nicely in the glovebox.
Old 12-08-2022, 08:43 AM
  #557
Bgbldodge's Avatar
31gal tank, straps, and sending unit ordered.
Old 12-08-2022, 05:26 PM
  #558
Bgbldodge's Avatar
Headers and stage 8 locking hardware is on. Tank and parts shipped and should be here this weekend.
Old 12-08-2022, 05:42 PM
  #559
Custm2500's Rude Friend
1FastBrick's Avatar
The SPO label was affixed to the Glove Box originally.... obviously the adhesive let go.
What's the deal with the front shock just hanging their?
Old 12-08-2022, 05:58 PM
  #560
Bgbldodge's Avatar
The fact the label was still there is impressive.
The shocks are the new Bluetooth model. Allows for way more flex.
They also haven’t been bolted in to their mounts yet.
Quick Reply: 1984 K5 Blazer
